Sunsynk 8kw Screen Flashing
Hi there
I have had a Sunsynk 8kw inverter with 2 Hubble 5.5kw batteries now for just under a year to beat load shedding and it has worked really well.
This morning I noticed that the LCD screen on the inverter is flashing in a rebooting cycle and the lights indicating AC and normal don't light up. The inverter appears to operate normally and when load-shedding happened it happily switched over to the batteries. It also won't connect to the wifi now so I can't log anything.
I have tried switching the inverter off completely for 5 mins in the hope that "Have you tried switching it on and off" would fix it but it didn't.
When the screen does come on I can quickly navigate to the fault codes but there are none.
Help
  • 1 year later...
  • 4 months later...
  • 10 months later...
I also have the same issue. Its intermittent. The dongle is offline while this happens and data from the MODBUS is also offline. Inverter runs as per normal though.
I have removed the dongle and removed the WIFI board that dongle plugs into. There is a capacitor on the 12v rail that can cause issues, but removing the board verifies that this is not the problem here.
I have been advised to log a ticket to have the inverter collected and repaired, meaning I will be offline for a while.
Has anyone managed to resolve without sending the inverter off?
