April 15, 20233 yr Good morning! I have searched the forum for "Best Settings" but there are so many different answers that i thought I could ask. I have 12 x 105A Lead Acid batteries in Parrallel-Series to make up 48V with 3 x Vicron Balancers configured as the attachment. I have a 5500W Inverter set to charge at 50A. No solar panels. My inverter is configured as per the screenshots I know the cut-off voltage is set too low, but this is how i figured out to get a "best" accurate battery capacity reading I am new to this, pleae help if you have a moment Best Regards Jean Edited April 15, 20233 yr by Jean Vos
April 15, 20233 yr You need to check the charging recommendation for your batteries. The voltages seem high compared to the deep cycle batteries I had. You probably also want to add solar to reduce the impact of daytime cycles under stage 5 to 15. My lead acids only lasted a year.
