May 9, 20233 yr I went ahead and bought a Must brand inverter from GW. They gave me a bunch of settings to adjust: 2: AC input range = UPS 14: battery type = USE 17: bulk charging voltage = 14 18: floating charging voltage = 13.5 19: cut off = 11.2 Its on a hubble s100 lithium pack. The chg LED never stops blinking, and the fans keep turning on with about a minute gap in between. The screen does show bypass is on. Is this normal?
