May 14, 20233 yr hie guys,recently installed 5kw sunsynk inverter and 48v dyness battery ,the battery takes time to charge or doesn't charge at all,the bms is also not working ,whats the solution?
May 15, 20233 yr 8 hours ago, ckay said: hie guys,recently installed 5kw sunsynk inverter and 48v dyness battery ,the battery takes time to charge or doesn't charge at all,the bms is also not working ,whats the solution? How do you know the BMS is not working? Are the inverter settings for the battery correct? Post your settings so we can see what the issue may be.
