Esener 5.5Kw/5500w 100A Pure Sine Wave Solar Inverter & Solarix Esener 51.2V 100Sh LiFePo4 Single Battery
Good day,
I’m looking at installing a backup system, I will look at installing solar panels at a later stage, using the Esener 5.5Kw/5500w 100A Pure Sine Wave Solar Inverter (5.5KW-48-P) or the Growatt SPF 5000 ES inverter in combination with the Solarix Esener 51.2V 100Sh LiFePo4 Single Battery Module-LCD Control panel. I will be using the backup system purely for essentials. The stove is already gas and the geyser is solar / tubes.
Is there anyone currently with this setup? If so, how are you finding the setup so far? How much load have you ran through the inverter? Any issues you're currently experiencing or you would like to point out? Can you pickup when loadshedding kicks in with lights dimming or appliances going off and on for a few milliseconds?
Looking forward to hearing your feedback and experience.
