June 1, 20233 yr Hi I have a Greenrich UP5000 attached too a Sunsynk inverter. I would like to connect a second battery. I found a Greenrich WM5000, are the too batteries compatible? Will the BMS work?
June 2, 20233 yr 23 hours ago, Roy Squires said: Hi I have a Greenrich UP5000 attached too a Sunsynk inverter. I would like to connect a second battery. I found a Greenrich WM5000, are the too batteries compatible? Will the BMS work? Specs look similar on the surface - one is rack mount the other wall mounted - Same manufacturer so good chance they will work - but cannot give a definitive yes.
