June 19, 20233 yr Hi all, does anyone know why the supply/charge from PV and battery total would exceed load by some 25 to 30% particularly in the morning when SOC at around 40%? I have 5kwh Sunsync inverter and 10kwh Freedom Won battery. Regards, Mark
June 27, 20233 yr Hi Mark, How did you setup your Solar on the inverter? Did you change the option to PV first then grid. Also what time in the morning? The strain on utility grid has peak and off peak. 10Kwh battery to a 5Kw inverter is a big boy, I usually combine a 5.12kw battery to a 5kw inverter. If you can maybe share a bit more re the programming and setup, we could find the root of mystery for you. lol
June 28, 20233 yr Author Thanks Ripley. Please see settings attached. Set on priority load and all on essentials which I manage ,(no non essentials). Average of 3kwh from grid per day, better in summer.
