July 1, 20233 yr I've been trying to setup smart loads on a 8kW Deye Hybrid Inverter. What I noticed is that on the GEN PORT USE I couldn't find the blocks for setting the smart loads parameters on and off as a result I couldn't complete the settings. I have already the loads split on the main DB but there is no outgoing power for the smart loads. Can anyone tell me what I've done wrong.
July 2, 20233 yr Maybe I’m not understanding properly but shouldn’t it be set to “smart load output” and not “generator input”? That port can be set to be an input or an output.
July 3, 20233 yr Author The smart loads are supposed to be connected on the generator input. After that the settings are made by clicking "Smart Load Output" but when I do that the inverter does not change and give me an output so that I can feed the smart loads.
