Sunsynk "daily" numbers resetting to 0
Good afternoon
Hoping someone can point me in the right direction.
It's happened twice where the various "daily" or "today" numbers for my inverter resets to 0 at 3:30am and it also happened after 2pm yesterday.
Examples are, "Import", "Daily production", "Today charging", "Daily consumption". These should only zero at midnight. I can see this happening on the sunsynk portal, and in the values I pull directly from the inverter. The "Total" values for the above figures are not affected and do not reset.
2 possible reasons that I can think of is the inverter rebooting, or it somehow thinks it's midnight.
I don't think it's rebooting, I have checks that should alert me to this(and the lights will go off?).
The clock is set to sync, and is accurate at the moment. I'm going to pull the time values from the inverter to rule out the clock being faulty.
Has anyone else experienced this? Or have an idea what might have caused it?
Thank you
Maybe your inverter is going offline and the clock is trying to sync from the internet during that period. Under Basic settings is sync turned on? I have exactly the same problem, usually when the inverter is offline. I have switched off sync and will see if it still happens.
