August 6, 20233 yr Hello, i want to send a command over MQTT or HTTP (idk which is easier) from my raspberry pi to the Deye inverter, to enable/disable the charging of my battery. Is there an easy way to do this? I've searched a lot online, but couldnt find anything helpfull so far. Or is this not allowed or sth? Greetings, Sammy
August 6, 20233 yr Hi Sammy1337 Do you have the raspberry pi connected via rs485 to the inverter ? The attached document contains modbus mapping for sunsynk , it seems to work fine for the 8kW deye. It should be easy to set up using node red and modbus . sunsynk_modbus.docx
