What is a DEYE Sun-5K-SG03LP1 system based efficiency
As many, I read that inverter efficiency is high - above 95% -, MPPT efficiency is given up to 97% but what really these numbers mean ?
What is the "efficiency" of a battery that drain few hundreds Wh per day just for floating and running the BMS and what's the charge/discharge ratio ? etc.
I run a basic solar station with 4.9 kWc solar panels, a Deye 5K inverter and a 3.5kWh Pylontech battery.
Using solarmanpv and home assistant, I can monitor the whole system and I get very surprised when starting to analyzed the data.
The losses look so high - about 20 % - that I questioned myself, where did I make the mistake.
==> This post is for discussion about the most accurate way for estimating/measuring the actual system losses.
Production comes from solar panels, battery discharge and grid.
Consumption concerns loads, battery charging and ... losses.
I compute the instant and daily  losses in the diagrams using the two variables above.
==> Of course there could be a shift in the daily figure because you can charge the battery one day and discharged it the other day.
Losses come from the 4 different converters inside the Deye inverter:
  • Inverter (48V DC to 240V AC)
  • Battery charger (240V AC to 48V DC or 48V DC/DC)
  • 2 MPPT (35-40V DC panels to 48V bus)
To be accurate, we could also take into account the consumptions of the controller and the BMS.
Considering the internal temperatures :
  • about 50°C for the AC part
  • about 60°C for the DC part
==> The losses per day (2kWh) are not so inconsistent !
Question : how much the efficiency of the converters dependent of the power ?
In fact, inverters are not good working at low power such as the 4kWh per day !
An other point concerns the accuracy of the sensors which of course are not high precision sensors and could generate some errors in the measurements.
I tried to get more information about the Deye 5K inverter bloc diagrams without real success.
I ended with the diagram below where I supposed the sensors are located.
(Feel free to comment or add correction to this diagram if needed)
As preliminary conclusion, the whole system efficient of 80% does not seem so wrong.
  • AC inverter losses are about 50-60W
  • the 2 MPPT losses are about the same
  • The battery charger does not seem very efficient regarding charge power vs discharge power.
Edited by SDABU
