August 29, 20232 yr I've got 5 340w panels in series an 1 in parallel 4 facing east due to the roofs direction which I would like to change but space is an issue. 2 of them are on the north side and only get sun around 10 or so. My solar panel icon flash's until about 10:00 - 10:30. My PV voltage sits between 119 and 130 max throughout the day. Anyway we can improve the set up?
August 29, 20232 yr 1 hour ago, AndrewO said: I've got 5 340w panels in series an 1 in parallel 4 facing east due to the roofs direction which I would like to change but space is an issue. 2 of them are on the north side and only get sun around 10 or so. My solar panel icon flash's until about 10:00 - 10:30. My PV voltage sits between 119 and 130 max throughout the day. Anyway we can improve the set up? The one in parallel is pulling the other 4 down. Disconnect it and it should work. You need at least 120V for PV to operate meaning 4 in series. Try as close as possible to use the same direction but never south. Edited August 29, 20232 yr by Scorp007
