September 6, 20232 yr Hi all Having a tripping issue with the inverter supply breaker. Inv 5kw deye paired with 1x am2 hubble Currently no heavy load, just a couple of fridges and lights as it's a holiday house. Charge current set to 40amps. Breaker size 30amp CBI I've used this size breaker and same setting for about 30 installs and never had an issue before. I suspect faulty breaker even though it's brand new. Or I need to change a setting or install a 35amp breaker as the max pass through current is 35amps. Any ideas?
