September 11, 20232 yr Hi All How long does CoCT take to install an AMI meter at the moment? Submitted application around 6 weeks ago, received Quote letter today and made payment. So waiting for the install and just want to get a feeling for how long the wait is going to be. Regards,
September 14, 20232 yr Hi All How long does CoCT take to install an AMI meter at the moment? Submitted application around 6 weeks ago, received Quote letter today and made payment. So waiting for the install and just want to get a feeling for how long the wait is going to be. Regards, I'm wanting to go this route, how much was the quote for the new meter?
September 18, 20232 yr Author R9,137 Ex VAT - Exactly like indicated in CoCT tariff sheet. You apply and then they send you a quote (No Cost if you are Resi, Small Commercial). Then you can decide if you want to go ahead
September 18, 20232 yr R9,137 Ex VAT - Exactly like indicated in CoCT tariff sheet. You apply and then they send you a quote (No Cost if you are Resi, Small Commercial). Then you can decide if you want to go ahead No cost if you're residential?
October 9, 20232 yr Author FEEDBACK - Just had the AMI Meter Installed today. So 10-11 Weeks from application. But then, applied for 2 AMI on 2 sites on the same day. The other one still waiting for a quote!!!!
October 9, 20232 yr Thanks for the feedback @Louw. Do you know how this meter works? Can you use the kW/h units you generate in the month at night or do they pay for every kW/h you generate at the feed-in tariff and you must buy every grid kW/h at the normal tariff rate? I guess it is probably the latter as that makes the most sense for the CoCT. I'm still waiting for my SSEG app to be approved, how do I submit an application for an AMI meter in the mean time?
