September 25, 20232 yr I would like to ask if Deye lithium battery that is in the photo is compatible with Growatt SPF 5000 ES via BMS cable. The battery seems to be pretty good but I would like to know if it is compatible via BMS so I don't put the battery in user mode on the inverter And if it is compatible, what is the protocol that I should use on the inverter ?
March 11, 20251 yr Author 16 hours ago, Koffee said:did u end up trying if they are compatible?It didn't connect, and I didn't follow up, I just put the inverter on USE and put the parameters on battery
March 11, 20251 yr 2 hours ago, Taher Sylla said:It didn't connect, and I didn't follow up, I just put the inverter on USE and put the parameters on batteryoh nice thanks for the reply man appreciate it <3
March 12, 20251 yr Author 18 hours ago, Koffee said:oh nice thanks for the reply man appreciate it <3Yes, I asked someone and he said it could connect but it needs an update for BMS, you can check with Deye aftersales or your local service center
