September 27, 20232 yr Hi. I have 4 solar panels and a victron charge controller. Trying to figure out if I must or can connect in series. I can't attach a photo of panle here but the charge controller is MPPT 100/30 vitron. A series collaboration would be easiest. Into a lipo 200 AH battery. Thanks in advance
September 28, 20232 yr Hi. I have 4 solar panels and a victron charge controller. Trying to figure out if I must or can connect in series. I can't attach a photo of panle here but the charge controller is MPPT 100/30 vitron. A series collaboration would be easiest. Into a lipo 200 AH battery. Thanks in advance I take it your panels will have a Voc of over 22V each. In that case no you cannot connect in series. If the panels are over about 380W you might not even be able to connect 2 in series. For a clear answer provide the Voc voltage of the panels or the make, size and model.
