Luxpower Hybrid 6 kwh - Eps setting on
Hello everyone, I have a 6 kWh Lux Power Tek Inverter with 11 Dyness B4850 2.4kWh lithium batteries. I would like to activate the EPS so that in
lack of power, intervene and do not turn off the inverter. In the settings I activated EPS but it is in Standby and does not activate in the absence of network. Do I need to activate anything else or are the settings not sufficient? Is Lìeps an integrated function or is it necessary to install an uninterruptible power supply?
