Real Time Graphs
Hi to all,
Is there any person who perhaps have 10 or more 300 - 350W solar panels that uploads the data to pvoutput.org and would not mind me having a look at the graphs.
Regards
I assume that you want to compare your own panels performance ...
When I first started with solar I wanted to "make sure" that the system was running optimal (We were off grid). I have four string of three panels each so I would disconnect all the strings and then enabled one string at a time with a kettle or heater running , yes I would pull a bit from the batts but it also meant that I would be running the string at full capacity. If all is well each string should be very close to each other , that is if they are facing all the same direction at the same angle with out any shadows. Lucky for me they have always been spot on.
Not sure how your installation was done but if possible it is worth a shot.
Many thanks I thought you are grid tied. I only have 6 x 235w and 2 x 250W.  2in series 4 in parallel.
Edited by Erastus
Sure, I have 20 x 310W panels
