ESENER 51.2V100Ah Rack Mount Lithium Battery Compatibility List / Settings
Any possibility of adding the Inverter BMS Li settings or protocols to be applied
i.e. an Inverter guide
This is an example, obviously not for your battery but this is how other battery distributers typically explain the process.
  1. Use CAN out on MASTER to Luxpower inverter.
  2. On the SNA, go to the MENU.
  3. Select option 3 for Battery settings.
  4. Select Lithium battery
  5. Select BRAND 2
