Sunsynk 8kw Battery Charge Rate off Grid
Afternoon all
Hope someone here could assist.
I see when i charge off the grid i only get around 2.5kw of charge going into the batteries. I wanted to find out if there is a setting one can change to allow for faster charging.
Sorry if this question has been asked before.
TIA
You'd set this on the inverter,
On the 'Battery Setup' page is a setting called 'Charge Amps' which controls charging current. Assuming a ~50V battery, it sounds like you're currently on 50A (since 50A * 50V = 2 500W).
You can increase this 'Charge Amps' to charge it faster; just check the spec-sheet of your battery first to make sure you're not exceeding the maximum allowed charging Amps of the battery.
