Sunmagic er134
Hi all.
I have a 5kva inverter connected to 4 x 100ah gel batteries. They only run plugs and lights. Yesterday after loadshedding kicked in the unit ran for 10 minutes with no issue then began beeping and went into error 134. I reset and then it kept trying to power up and went on and off. Same 134 error
The first set Of batteries lasted 18 months and gave obvious signs they were on the way out. They started dying alot faster eventually only lasting 20 minutes in loadshedding. These newer ones I've put have been since Feb. There has been no sign of them beginning to die and even in a 4 hour loadshedding schedule they dropped to 75% remaining life at most.
Anyone have any suggestions as to what to look for?
