January 9, 20242 yr Hi All, I have a Sunsynk 8kW inverter, 10 Canadian Solar 550W panels and 2 Freedom Won 5 Kwh batteries. I have everything on the critical load except my geyser and oven. I am currently using the 'push back" functionality to power these non-critical items when I have excess solar. To do this on System2, I have ticked "Zero Export" and "Priority Load" only and have set my Grid trickle to 20W and my Export Power limiter to 8000W. My questions are the following: 1) Will the above setting power the non-critical items using battery power (if the SOC is above System1 settings) even when there is no additional solar? (e.g. can I use my battery power to heat the geyser at 4am) with my settings as above as long as I have enough battery power?) 2) If not, can you use the "push back" functionality to use additional solar during the day and the "smart load" functionality at night for non-critical loads? What are the practical considerations here... I don't have to have to be flicking switches every evening to make this happen. Many thanks in advance for your input. Cheers, Frank
