  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
High apparent current in Goodwe triphase inverter
Hello from the other hemisphereย ๐Ÿ˜€.
My ET triphase inverter shows a strange amount of apparent current (around 400VA per phase) when there are no loads (less than 50w or the house completely switched off) and no PV.
The image below is taken from Home Assistant and is confimed also by the readings of a current clamp.
Can anybody tell me if their inverter is showing such apparent current (and corresponding reactive current and low power factor)?
Thanks in advance.
Marco
P.S: I am asking this because I suspect that the inverter is faulty but I am struggling with Goodwe support to acknowledge it.
  2. Tap Permissions โ†’ Notifications.
