solar direct to geyser
19 hours ago, brooks africa said:
Hi question by a dummy.
Can I change my traditional geyser element to a 12 v Dc one and run straight from a solar panel ?
The common panels are 35-50V so the answer is no. There are 100W panels normally seen as 12V panels but you need a massive current to do meaningful heating. A 150L geyser needs 7kWh to heat from 20 to 60 degrees.
