March 23, 20242 yr Greetings I am currently sittting with a slight issue. I installed a 8kW Sunynk Inverter about 2 weeks ago. I had created the plant and linked the data logger with the client's WIFI. Everything was running smoothly and I could monitor the data remotely. Then the app updated and I had to relogin. Ever since then I can't see the plant anymore and I spoke with Sunsynk and they say that the Data logger is offline ( whereas it is clearly online) Is there a way I can reset the Data Logger and try and reintergrate it again ?
