April 24, 20242 yr Hi All, I have a Vito 10.2K48 Inverter, i assume its an axpert Invertor and I have 12x 450 Watt Solar Panels. I am trying to do calculations but run into one problem, the invertor Imax PV=18Amp and i dont know how to best arrange my panels. Please Help - Inverter Specs: 10,2kw Nominal DC Input Voltage 48 PV1 5400 watts PV2 5400 watts imax pv 18 amp Nominal pv voltage 360 vdc pv array mppt volt range 90 450 vdc max pv open circuit voltage 500 vdc max charge current 160 amp Panel NOC STC Wp 340 450 vmp 32,51 34,67 VDC imp 10,46 12,98 Amp voc 38,65 41,25 Vdc isc 11,08 13,89 Amp
