Rct 3Kw axpert inverter
Good day I need some advice and help.
We had load shedding and switched inverter on everything was ok. After switch over to grid to charge batteries the inverter started smoking and the battery fuse blew. i changed the fuse and it blew again what seems to be the problem. Thank you
