SRNE All in One SR-EOV05C - Discharge Option
Good day all,
I'm new to all of this and still finding my way of getting the best out of my installation.
I recently installed an SRNE SR-EOV5C 5KVA in one inverter battery system. The system does what its meant to but I'm struggling to get the inverter to stop discharging the batteries at a certain percentage.
As per the manual, parameter 04 states  "Battery to Mains - When the Parameter [01] =BT1ST/PV1ST, the battery voltage is lower than the set value, and the output is switched from inverter to Mains Power, and the set range is 40V~52V."
The inverter is set to BT1ST which gives the battery priority then switches to PV and then mains if all fails. No matter what voltage I set to parameter 04, the unit just wont stop discharging the batteries.
Has anyone had this issue and know any solution to this?
R
  • 1 year later...
Hello, did you manage to resolve the issue? Please share also whether you are feeding to the grid and share connection guides if you have any. I have a SRNE EOT50s which I want to connect to grid so that I can feedback and also link it to my critical loads only since my load at peak is higher that 5KW. Any guidance will go a long way.
Edited by Ontak
Correct model number of SRNE all in one.
