October 11, 20241 yr Greetings all, I have installed a back up system consisting of the dyness bx51100 battery and the growatt 6000es. I’m new in this, so I’m not sure if the run light should constantly be on or flicker when the battery is fully charged, I would also like to know if there is any one with a similar setup, what settings did they use on the inverter to ensure battery optimisation.
