Inverter started using maximum load at random times
This may be completely coincidental but I had a new battery installed and I assumed the guys had to change some settings for this too.
Now the inverter randomly starts drawing the maximum load (5kW) from either the battery or AC and only stops if I flip the "To A/C Combiner" switch on my main DB. At that point the AC to the inverter goes away and I run completely from battery but the load on the inverter/battery stops immediately. Any ideas?
This is what it looks like on the app, I got home at just after 10 and saw the load being 5kW at which point I flipped the switch and it wen't back to just powering what we have turned on in the house.
Edited by axisK
Got the guys to come back and it seems the CT clamp was on the wrong wire. They've fixed it now and it looks to be back to normal (will see over the next few days).
Still don't have data on how much load I'm getting from the grid though.
