November 4, 20241 yr I am interested in upgrading to the Luxpower SNA6000, is the app/remote access useful for configuring? Also, can it be configured so that it can work with the Smarthome or Tuya platform, or what is recommended? Example: automatically adjust charging profiles from solar based on weather forecast? Or turn non-essential loads onto mains supply instead when sun time is reduced by weather conditions?
November 5, 20241 yr Its unlikely to work directly with Smartthings or Tuya apps. You would need to use something like HomeAssistant. Your Tuya / Smartthings devices would be brought into HA as well as the Luxpower data - then you run the automations from there
