December 19, 20241 yr Hi Everyone I have an issue with my borehole pump. Each time I turn it on, it trips the Earth Leakage. I checked the wires, nothing is loose or disconnected. Any ideas on what the issue could be?
December 20, 20241 yr On 2024/12/19 at 12:29 PM, Anton18432 said: Hi Everyone I have an issue with my borehole pump. Each time I turn it on, it trips the Earth Leakage. I checked the wires, nothing is loose or disconnected. Any ideas on what the issue could be? 1st you have to measure if the cable or pump motor is not moisture filled and that the earth leakage is operation the way it should.
