January 29, 20251 yr Hello friends, I am using Voltronic Infini Solar 15kw three phase hybrid inverter with CFE 5100 lithium battery. Inverter and battery communication is provided properly. I can see Li-on and SOC value on the screen. But my main problem is that when SOC reaches 100, the charging current automatically drops to 1A. When SOC drops, the charging current remains at 1 and does not increase. Therefore, I cannot charge my battery. Do you have a solution or have you encountered this situation before? Thank you.
