February 16, 20251 yr Hi I have a 3-phase supply from Eskom, and currently have the inverter on a single phase. This means that my load is not properly balanced with more load on the phase with the inverter. With the requirement to register as an SSEG becoming seemingly more important, will this be an issue? 1. Is SSEG registration needed? What are the consequences of not registering? 2. Would I need a 3-phase inverter (or one inverter per phase) or am I fine having only one phase backed-up?
