Help to correctly wire 3 phase Deye inverter to sub db board
Hi All
I would appreciate some assistance
My house is 3 phase but I’ve always only use 1 phase for most of the circuit breakers through a 7.2 kw synapse / axpert inverter in parallel. With a 20k battery bank 5kw x 4.
Both inverters blew this weekend and I’ve decided to get a 12kw deye 3 phase inverter and properly load balance the phases.
My question is how do I correctly wire the 3 phase inverter via the sub db board with changeover etc back to my current db board.
I’m used to only 1 phase positive & neutral setup so not sure how to correctly wire the 3 phases into changeover etc.
The sub db I’m going to use is this below.
Your assistance is always appreciated
Solar Warehouse SA
No image preview
Three Phase AC input & output Populated Distribution Boar...
Wired and ready to use Three Phase AC input & output Populated Distribution Board ONLINE DEAL Populated distribution box includes: 1x 18 Way IP65 Waterproof Box1x 63A 49 3KA MCE Circuit Breaker...
