March 18, 20251 yr Hi folks,I was given a ShineWifi-F dongle by @Demo after his Growatt inverter was water damaged. There are a few threads about reprogramming the Shine-Wifi-F dongles (e.g. https://diysolarforum.com/threads/hacking-the-new-growatt-wifi-f-modules.43231/), but one of the constant problems is programming it, because of the RS-232 transceiver connected to the ESP07 modules RX and TX pins. Some folks desoldered the transceiver, others cut traces, etc. Some had success with particular USB-TTL adapters, but the CP2102 that was said to work there didn't work for me. Others had problems providing enough power.I approached it somewhat differently, starting with a USB-RS232 dongle, and a RS232 breakout board. I cut a USB extension cable in half, and connected the white wire to the TX pin (pin 2) of the breakout, and the green wire to the RX pin (pin 3). Black obviously went to pin 5 (Ground), and red went to pin 9 (Ring Indicator). In fact, the red wire doesn't need to be connected to the breakout at all, but it simplified things physically. I also had a 12V supply, which I connected to pin 9 and pin 5, to provide power to the dongle. I also put a jumper between Ground and GPIO0 on the dongle to put it into programming mode when power was applied.With that done, I could simply run esptool.py to pull the original firmware off as a backup, and then install my own ESPHome firmware on it.Thanks again to @Demo for the dongle.
March 18, 20251 yr Author Here is the YAML that I came up with. Note that the ESP07S is quite RAM limited, and I ran into "Out of Memory" conditions when enabling too many features. Main symptom of this was failure to connect to WiFi, or failure to complete OTA updates (leaving the esphome program on the client hanging)!esphome: name: growatt friendly_name: Growatt esp8266: board: esp07s # Disable logging logger: # level: VERY_VERBOSE # level: INFO # the below lines move logging to the alternate UART pins # this exposes the TX line on the GD25Q SPI flash CS pin #1 # which can be snooped with a chip clip or pin grabbers. GND is pin #4 # If you want to keep the hardware UART for the modbus uart, # uncomment the baud_rate, and comment the hardware_uart # This is advised for "production" deployment! # baud_rate: 0 hardware_uart: UART0_SWAP # Make sure that the logger level is at least DEBUG # This is good for monitoring free heap space, etc # .debug.yaml simply contains the example configuration from # https://esphome.io/components/debug.html # <<: !include .debug.yaml # Disabled by default, because of limited RAM # required for the pcf8563 #i2c: # scl: GPIO4 # sda: GPIO5 time: - platform: sntp id: sntp_time # on_time_sync: # then: # pcf8563.write_time: # - platform: pcf8563 # id: pcf8563_time # address: 0x51 # SPI bus is connected to the GD25Qxxxx SPI NOR Flash chip # Mine was covered with conformal coating, so I couldn't make out the # exact part number # e.g. https://eu.mouser.com/datasheet/2/870/gd25q64e_rev1_4_20210820-1825464.pdf #spi: # clk_pin: GPIO14 # mosi_pin: GPIO13 # miso_pin: GPIO12 # There's no support for flash chips in ESPHome at the moment # But the CS pin is GPIO15 # Enable Home Assistant API api: ota: platform: esphome wifi: ssid: !secret wifi_ssid password: !secret wifi_password # Enable fallback hotspot (captive portal) in case wifi connection fails ap: ssid: "Growatt Fallback Hotspot" captive_portal: #web_server: light: - platform: status_led id: status_led_ output: led_red internal: true output: # Green LED - id: led_green platform: gpio pin: GPIO0 # Red LED - id: led_red platform: gpio pin: GPIO2 # Blue LED - id: led_blue platform: gpio pin: GPIO16 uart: - id: modbus_uart_master baud_rate: 9600 rx_pin: GPIO3 tx_pin: GPIO1 # debug: # direction: BOTH button: - platform: safe_mode name: "Safe mode" binary_sensor: # The button is connected to the ADC - platform: analog_threshold name: Button sensor_id: adc_button threshold: 0.5 filters: invert: sensor: - platform: uptime name: Uptime Sensor entity_category: diagnostic - platform: wifi_signal name: "WiFi Signal Sensor" update_interval: 60s entity_category: diagnostic - platform: adc pin: GPIO17 id: adc_button update_interval: 1s filters: delta: 0.1 # Use the stream_server for remote modbus RTU access #external_components: # - source: github://oxan/esphome-stream-server #stream_server: # - uart_id: modbus_uart_master # port: 502 modbus: - id: modbus_master uart_id: modbus_uart_master modbus_controller: - id: growatt_master address: 0x1 modbus_id: modbus_master setup_priority: -10 # .growatt.yaml contains the modbus register definitions packages: master_inverter: !include file: .growatt.yaml vars: modbus_device: 1 modbus_controller_id: growatt_master inverter: Master
March 24, 20251 yr Author Turns out I was somehow using an older version of ESPHome, which contributed to the Out of Memory problems I was having. Try make sure you have an up-to-date installation. I recovered about 10-14kB doing so! 20%!!
