March 22, 20251 yr I am new, and already purchased one panel specs:The specs of my Navasolar inverter are:On their website the maximum wattage is Solar ChargerMaximum PV Array Power : 1500WMPPT Range @ Operating Voltage : 30~115VDCVDCMaximum PV Array Open Circuit Voltage : 145VDCMaximum Solar Charge Current : 60AMaximum AC Charge Current :60AMaximum Charge Current : 60AorAlso, as I am new, when there is no loadshedding is any of the excess solar (assuming batteries are full) supplied to the loads I have on it? Edited March 22, 20251 yr by Pebbles
March 22, 20251 yr Buy two more identical panels, put all three in parallel, install in the same plane and use 6mm² PV cable. Solar will go to both battery and load when there is loadshedding. Depending on the inverter features, it should be the same with grid available.
