April 15, 20251 yr I have recently had a three phase 12k Sunsynk inverter installed with 18 435w panels and 4 x 10.6 kW Sunsynk Batteries there are no onboard ct clamps due to distance being about 18m so there is a rs485 link to a three phase eastron.I purchased solar assistant with a can and rs485 splitter plus rs485 lead.Everything looks fine but im a bit perplexed by the numbers im seeing.Why would the Ac Output Power be negative on phase2 and the grid power be positive, does this look like a clamp ?
