Deye Parallell battery connection
Hi, when connecting in parallel I see battery comms from battery bank only to master ? Does the slave also need battery comms as I see the slave drawing battery power while the master is not ?
Yes, the slave also needs battery communication, otherwise your inverter will only see 1 battery.
3 Batteries in one bank connected to master via comms cable, bank connected via fuse to both inverters. Pls advise how to connect slave battery comms ?
