September 15, 2025Sep 15 At Lithium Batteries South Africa (LBSA), we design our products with one core principle in mind: your energy system should grow with you - not against you.That’s why all of our wall-mounted LiFePO₄ batteries, from the original 5.1kWh to the 10.6kWh powerhouse, are fully interoperable. Whether you’re upgrading an existing setup, adding capacity, or building a large system with mixed battery sizes, LBSA batteries work together flawlessly.Built to Mix, Ready to ScaleAll LBSA batteries share the same:51.2V system voltageSmart BMS communicationLiFePO₄ (Lithium Iron Phosphate) chemistryWall-mount designThat means you can combine different capacities - 5.1kWh, 5.3kWh, 6.1kWh, and 10.6kWh - in a single system without needing to:Modify wiringUpdate firmwareChange inverter settingsIt’s plug-and-play scalability - made for real-world installers, real homes, and growing energy needs.Why It MattersFor installers and system owners, backward compatibility means you don’t need to wait for a full battery replacement cycle to upgrade. Want to add more capacity to your 5.1kWh system? Just pop in a 5.3kWh and keep going.It’s future-proof, budget-friendly, and totally stress-free. Key Benefits of LBSA Cross-CompatibilityFuture-proof your system – expand when you're readyCost-effective upgrades – no need to replace full banksInstaller-friendly – easy setup, no complicated tweaksReliable performance – same high-quality BMS and LiFePO₄ chemistry across all modelsStylish black finish – consistent design for clean installsPower That Evolves With YouWith LBSA’s backward and forward compatibility, your energy system grows with your needs - not your headaches.Whether you're replacing one unit, scaling a hybrid array, or building from the ground up, you can mix and match with confidence.One system. Four sizes. Endless flexibility.Proudly manufactured in South Africa.
