Chris van der Linde
Hi there , would like to find out if you can load your solar batteries with a secondary inverter that is hooked up to a generator(dedicated for only loading batteries). Have someone local that have a 15kw system(3 X Sunsynk 5kw inverters). Then there is a generator hooked up to a 5kw Growatt inverter that feed the batteries. Do not know how the BMS is influenced on the system since it communicate to the main 15kw Sunsynk inverters.
