December 10, 2025Dec 10 SECONDARY INVERTER DEDICATED TO ONLY LOAD SOLAR BATTERIESHi , i would like to know if anyone have knowledge on using a secondary inverter hooked up to a generator with the sole purpose of loading the inverter batteries only. Have someone local that have a 15kw(3X 3kw Sunsynk system) then they have connected a Growatt 5kw inverter to a generator that is only used to load the batteries. Do not know how the BMS of the batteries is affected or how this is possible. If anyone have knowledge could you please share this info
