December 31, 2025Dec 31 Hi All, I am running 2 Deye 12k Inverters as Master/Slave using Solar Assistant <> Home Assistant. I would like to put an automation in place which switches the inverters to standby mode after sunset when the battery is empty. I just can not find the switch tho change the Deye 12K inverters to standby. Gemini insists that there should be either a "Inverter Power" or "System Mode" Setting(apparently referring to modbus register 80) somewhere in Solar Assistant which I cant seem to find. Can you please advise where I can find the setting or how I put my inverters into standby remotely? Thank you very much & Best Regards, Daniel
