June 12Jun 12 "I am facing an issue with my energya MAX-8000 inverter connected to 5 Pylontech UF5000 batteries. The system runs the loads from the batteries until they reach 42V, at which point the batteries shut down. The next day, when the sun rises, the batteries remain in a disconnected state. To initiate charging, I have to manually press the reset button on the batteries.The inverter recognizes the batteries and the installation is correct; however, I suspect the device might need a firmware update, as I am able to edit setting #29 on the device."
