June 14Jun 14 I have crown elego 6kw inverter (pdf enclosed)I have just bought Dyness Powerbrick SC 16kwh LIFEpo4 battery (pdf enclosed)I have tried a lot for bms connection between the two but in vainneed detail support for bms connection between these two Crown elego.pdf 111Dyness PowerBrickSC16kwh Datasheet EN20251030.pdf
June 14Jun 14 Are you using a standard LAN cable for the comms?You will need to verify the pinouts for both the Inverter and Battery to make up a cable if both are not standard pin outs.You will have to get a similar schematic for battery and Inverter.
June 14Jun 14 Author Thx for replying I have made customized cable with rj45 connectorsBattery side pin 1 & 2 are connected to inv side pin 3 & 5 respectively Still no bmsNeed help
June 14Jun 14 Author Crown elego supports oith CAN and rs485But what are the exact settings for bms?Need reply or actual demo video from an expert plz
