1 hour ago1 hr My current set-up consists of 3 Axpert MAXII 11KW in parallel (1 inverter/phase), connected to 6 x Greenrich Lithium batteries U-P5000 via an ad-hoc Voltronic cable (BMS inverter port to the RS485 batterie port).The issue is that even though the inverters’ program 16 is set on OSO, it seems that the batteries are still getting charged by the utility at night.What I am trying to achieve is to make the most of the solar & batteries combined, with batteries only getting charged by the solar. You will find here attached more details on the current set-upThanks for your help.Kind regards / Yves Inverter & battery set-up.pdf
