April 28, 20197 yr Hello Anyone familiar with the GW5048D ? there's a new White unit out. Is there any difference between the white and older yellow unit? Also the max PV is 6500W with 30% PV oversizing? So if you not facing north and being not at the correct angle one could add a few more panel to say 7500W without any issues ? As long as its with voltage and current limits? Does this mean you can only do 3250W per PV input or can it be say 4000W and 2500W on the other? When setting it to zero back feed do many people have problems with there prepaid meters tripping? https://nl.goodwe.com/Public/Uploads/products/GoodWE product page_ES.pdf Edited April 28, 20197 yr by RichieRich
