February 4, 20206 yr afternoon is there anyone with a link that will take me to the login page of the raspberry pi 3. i have the username and password but i cannot find the login page. Sleeeper
April 8, 20206 yr If this is for a normal Pi it all depends on what you installed on your Pi and if it has a UI or if you need to connect using SSH. If however you are using your Pi with Victron VenusOS then just load VictronConnect to you phone connected on the same Wifi as the Pi and you should see the Pi there. It has a link to the log in age.
