June 27, 20205 yr Hi, When I bought this inverter it came with a Raspberry and some cables and pieces probably to set up using a laptop. What will I require to do online monitoring through my cellphone? It took forever to get my Schneider online as the port forwarding and cell call centers seems to don’t what I needed. Now with the Schneider I can go online and setup or look at all trends. What nobody told me...........After the Port Forwarding (NIP.com )I needed a dedicated IP address. For using my Vodafone cell phone I had to send them a application forUnrestricted APN and a copy of my ID. Then all was sorted. If there was a easier way I surely missed it. Anyway it now works every time. solarflare
June 27, 20205 yr 1 hour ago, Solar Flare said: When I bought this inverter it came with a Raspberry and some cables and pieces probably to set up using a laptop. What will I require to do online monitoring through my cellphone? Does the Raspberry also come with the ICC software and license? If yes, then you can use ICC to monitor your Axpert and either access the Raspberry Pi and ICC through VNC or have ICC post the data to Emoncms
