Need Help with possible overcharging
Good Morning All
I recently installed a backup system on my house, it consists of the following 5000Watt SSL Pure Sinewave  Inverter, 4 x 200AH Shoto 6-FMX-200 Batteries, 3x Battery Balancers, and a BMV 702.
After installing the BMV over the weekend and monitoring the charge values I noticed once the batteries are 'Fully charged' as per BMV the chargers voltage is still 55.02V and there is still a small current of around 0.22Amps indicated on the BMV after about 10hr of charging.
My concern is that if i calculate the Float Voltage of the batteries ( as per manufacturer 2.23V/Cell) or 13.38Vper battery I have a Battery bank Floating voltage of 53.52V as my batteries are series connected, will this over time overcharge the batteries?
I have no access to the inverter's charger settings as it is a very basic inverter.
I am rather new to this and any advise will be highly appreciated
Hello.
I have also 200AH batteries and my float voltage is 55.2V on my batteries. I don't think they will overcharge as it just keeps the voltage at 55.2V and the amps low.
I'm also in the process to get a extra 2 Battery Balancer from Victron I have 1 now. My Sister have the Battery Balancers on their system and their batteries is running smooth. no under or over charged on the batteries and plus BMV.
23 hours ago, Barryv said:
Hello.
Perfect, thanks that makes me feel better as at the moment i am switching the invert off when is see the charge current drops below 0.2Amps.
Since i only use the it for backup i do not have any panels attached to the system.
I have attached some pix of my system.
1 minute ago, NilsP said:
to what batteries are they connected to? I don't see it connect on your batteries!
I have order my Battery Balancer today.
Unfortunately i forgot to take a photo after i connected them, however i have attached the wiring diagram for you.
I can take a photo when i get home later
Awesome and good work how you have put the balancers..
So today load shedding is happening when I get home from work, then I can see what the batteries are doing.
  • 2 years later...
Good day, i have recently purchased the same inverter. Any feedback on it?
  • 10 months later...
